Mugabetown - Whoretownin' At It's Worst.
And the shenanigans begin... First monthly pay from decmil and I'm pretty sure I've just been paid my base salary with no site loading...
Thats far from ideal. I can see the two figures being very very different
SO, my afternoon and night got interesting yesterday. Was going to head out the the harry's meet cause i was bored as fark... Decided to put the front timing cover back on to make it look a bit better. Marked up the CAS and everything as normal, took it off then put it all back on as normal. Cranked it over and heard a crunch so shut it down and took it all apart again.
After a bit of probing and prodding, I found that the "half moon" nubs in the CAS and on the end of the cam must not have been lined up perfect and it snapped the one off the end of the cam.... Not an ideal situation.
After some head pondering between a mate and I we came to a resolution. We ended up being able to line up where the half moons would be and get the CAS back on in that spot then line up the original markings we made.
Put it all back together and started it up and it cranked over fine and sounded like normal. We free revved it a bit and all seemed good, next was time to take it for a drive and see what it was like under load. We started with normal driving and occasionally getting into boost, all seemed fine. We gradually started giving it more and more throttle and everything was good. Finally we did one last pull, full noise through all 5 gears and it was exactly the same as normal.
Even still I may look into a replacement cam just to be safe..
that's exactly how I busted my CAS Scottie and then car ran like shit.
Get checked over for sure
Its not the cas i broke, its the half moon on the end of the cam that snapped.
And gmorning all
It's Friday :)
And good morning Ants... I actually have tomorrow off sdo i may still head out to happy laps see how things go
oh. I thought the half moon CAS centre was not aligned and snapped!
My bad. Am still waking up
both half moons werent aligned properly and fouled on each other, however when i turned it over it was the one on the cam that decided to snap not the CAS. wish it was the CAS lol...
But yeah as i said a bit earlier there is no noticeable difference when driving the car. So "if" and thats a big "if" its out it can only a a degree or so as you cant hear or feel it.
wait. You talkin about the half moon seals that go on the head not being aligned right?
Its aligned now. Im talking about the half moon that is on the front end of the camshaft. Like pull off the CAS and look in the whole where the centre goes in and locks into place. In there.. See google pic below
thats what I initially thought. And that is exactly how I busted my CAS.
Scotty we have a car in ATM with this bit broken off
The cas is perfectly fine if you get it in the right tooth
Just get a timing light and chuck it on and make sure it's in the right spot before...... Giving it to it
It should be fine that way even with the broken half but it's completely up to you of you want to replace...... Then I buy cam :devil:
    • Assuming the current ECU is stock, it might be worth getting hold of a nissan data scan cable. It could be as simple as voltage at the ECU
    • You need to test for spark when it matters - ie cranking. Kill the fuel supply, pull a plug and earth it, set up a camera and go crank. The spark needs to be consistent, every other turn of the engine. Not some sputtering of occasional spark. The reason I say this is because spinning the CAS in the air is not the same as spinning it installed, and if there is a bearing problem in it, the disk might work differently in the air than in the engine. You won't want to try to set the timing unless you know the spark is happening right.  Also, reconsider running the R35 coils against the stock ECU. They like a different amount of dwell cf the originals. It's not massive, you can actually run them, but it is better if you can adjust the dwell (which you can with Nistune in the stocker, or with an aftermarket ECU). Besides any of that - when you had the multimeter out, have you got power where it needs to be, earth where it needs to be (and when, in the case of igniter triggers), etc?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
