Mugabetown - Whoretownin' At It's Worst.
It is cheap, they can be had for 3 parts of f**k all now.
Errr.. Not so much. Maintenance on them isn't cheap at all. You're still facing $10-15k for a 15 year old car that requires a fair amount of servicing and upkeep. That's similar pricing to 33 GTRs, so not cheap.
No matter how you slice it 10k - 15k is a cheap car. Out of interest maintenance wise, what is expensive about them?
All this talk about crank trigger.......and I too know about them benefits thanks to Bunta.
Thinking I now need to invest into one.....for reliability's sake
You are in the position that few of us are though, where everything is new and there is not much movement there, really you should be ok for a while, but if you do want one hit me up and I can get one built for you!
http://sethgodin.typepad.com/seths_blog/2014/03/what-does-its-too-expensive-mean.html Have a read of that and you'll see where I'm coming from.
Gear box is stupid expensive, however that's once every 100k km - hopefully. Plugs are all iridiums (could be platinums now that I think about it), coil packs are about 20% dearer than standard skylines, parts are rarer hence more dorras (window motors, fuel cap release motor, seat motors etc), sway bars are about $350 + shipping from the states because they're difficult to source here, exhausts are more expensive when you include stupid frieght rates. Overall, it all adds up for less performance.
interesting......
You would also change plugs a lot less, be kinder on your oil (not needing to cool turbos down) coilpacks should last due to less heat ect ect. The only one I can see is the extra electrics crapping out but that should be a long way off, I was speaking to Grahame the silver fox and he was saying his costs him fuark all.
interesting......
Ya Rly!
Ya Rly!
Mine's done about 120k km, which is when everything starts f**king out. Hence my level of frustration right now. Oil is still changed every 5k km. Plugs every 50km, which is probably next year. Coil packs are on their way out. Graham has also done significantly less ks than mine has. I think he's sitting at 70k-ish from memory.
Oh, and the bushes are starting to f**k out and need to get them done. and diff feels like it's on the go - not sure though.
All of this whilst saving like a flamin mongrel for a major investment which is due to be finalised in Sept - if all goes to plan. :rant:
Every car shits its pants around then, the little Mazda is about to start costing me money too damn it! But in June it will no longer be my problem so thats ok.
The frustration is amplified when the performance isn't there yet the parts cost more. It's a fun position to be in.
Oh well, you will know for next time!
wasn't aware that most of the stuff had to come from the states - which is what bugs me the most. So in short, it is not cheap. A $15k car that costs a mint to run isn't cheap.
I think the key difference here is your definition of a mint and my definition of a mint is quite different, everything you mention is, to my mind, typical of every car. However I must also say that I don't consider my car to cost a fortune to run either, even when I did drive it daily.
In short I guess I am saying "Damn son, Yo a whinger!" :P
Which is exactly what the link to Seth godins blog described.
Also, I'm going to be in a position in 6 months time when all my assets will be scrutinised, so I'm a little concerned.
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
