Mugabetown - Whoretownin' At It's Worst.
So problem number one............
There is a knocking noise from the rear when I brake or put the car in reverse. The best way I can describe is like backlash from within rear driveline, a bit like a weight being pushed forwards then going backwards. Its not a harsh noise.
I have had this problem ever since I have owned the car.
It does not happen all the the time but I would like to get rid of this pesky issue.
Im thinking the rear diff is the culprit.
Anyone have any thoughts?
How olds the diff, could be getting play in it and you're hearing the slop as it goes from forward to reverse and back again
I don't know about Cusco.
What I do know is that most 1.5 / 2 way jap diff tend to be a bit tough and clunky (friction plates)
With helical there is none of that and therefore is just smoother and runs quieter
Diffs are a bridge i'll have to cross at some point soon-ish i think.
You'll have to re get your exemption won't you?
Also, I have a hard decision to make. GC hinterland or Mt Nebo
Up tambo, down tambo, up Oreilleys... ah f**k this roadworks and the 1 lane road, back down Oreilleys, up tambo, down tambo...
Stopped in at Cedar creek on the way back down too, i think i'll have to bring boardies and a towel next time.
If I had today off I would come with you Pete
I'm not sure my car's good enough to be seen with yours (once you get it finished at least!)
probably one of the most underated mods you could do IMO.
Will do front one too after my bank account recovers.
Zac will be busy.
Well she is kinda finished. I'm even taking it with me to work FTM.
Just need to respray rear bar.
My car would be fine with yours or any other Nissan. Just no commodores
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
