Mugabetown - Whoretownin' At It's Worst.
I'm bored and proposing names for zacs new car
So far "The Lovechild" winning lol
Goon Balloon Mk 2.0...due to it being another Goon Balloon complete with boat trailer indicators.
Second day driving the GTR was really nice.
I forgot how low the car is and managed to pop out the passenger indicator out of its place.
The indicator still works but the mounting point is well........
*Le f**ked*
I have just ordered a new one.
Been an expensive day today with quaife diff and whiteline bushes :/
Well done mate. Looks good
So glad your back out driving this thing now... TIme to enjoy it and rack up them KM's
Do you have an idea of when you will be back for another tune and some E85? or just enjoying it for time being?
Decisions..... For a decent 34 it's 15 and for a amloast destroyed 33gtr it's 14
This makes it hard because either way I will be fixing stuff and changing, and of it's rooted I can fix it so not to much there, and will have a new engine either way....
Hmm
Hmm
I thought that we were just looking for a 33?
well with E85 being so close to me I would like it to be on E85 now.
But it would be best to give it km's first and then once I think it's done enough (maybe 3,000km, so another 2,400kmto go)
Certainly am enjoy it FTM :) :)
But it would be best to give it km's first and then once I think it's done enough (maybe 3,000km, so another 1,500
I agree with you here. Give the motor a heap of KM's on pump98 then give it some e85 when run in has finished.
WHat ECU is it again ? Can it be flex tuned
Hmm
Buy my leopard. Put 33 stuff in it. Massive win.
  • Like 1
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
