Mugabetown - Whoretownin' At It's Worst.
Planing on spending some time on the cars tomorrow
Going to rear seats out and probably attempt the under dash loom
And swap some locks around so they all work on one key and ill do the petrol flap latch
And I'll order my clutch fork release bearing from nissan :) $40 ;)
Depends how you look at it I guess. f**k being out there for 5 years though, gotta live aswell.
Saying that I'm meeting with some of our directors next week to discuss working in India, should be an interesting chat lol.
