Mugabetown - Whoretownin' At It's Worst.
I like blends.......with cola or other mixed drinks....,.not on their own......
^ pretty much this, I don't care what people say I'm not drinking dirty f**king balentines or cheap walkers straight when the sole purpose of drinking it is to get drunk, nice scotches yer straight cheap shit, bring on a f**k load of ice and Pepsi max
The purpose of drinking is not to get drunk. The purpose of drinking is to forget.
Well I can't see your build thread in here: http://www.skylinesaustralia.com/forums/forum/281-members-rides/
So I can only assume you have it somewhere else that I don't look :(
Because shit bloke. Only awesome cars are posted in the Members section. Cowdy requires approval from dirty Victorians and New South Welshman so posts it in the general area.
really? Where's the maxima build then?
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
