Mugabetown - Whoretownin' At It's Worst.
Car about to come off hoist soon
pix, pix, pix, pix, pix, PIX, PIX, PIX, PIX, PIX, PIX, PIX,PIX, PIX, PIX, PIX, PIX,PIX, PIX, PIX, PIX, PIX,PIX, PIX, PIX, PIX, PIX,PIX, PIX, PIX, PIX, PIX!!!!
Depends what you are after?
Got some volk racing c-ultra in 18x9 and 10, or some 19in forged lenso with near new rubber (265 and 245).
got any 18x10.5 with rubber?
I need them x 4
Link to the volks? (Just for the fact that I'm bored lol)
Buy my cooler pete. Genuiine Greddy 76mm
direct bolt onto gtr?
Buy my oil cooler/relocator kit Pete. PWR cooler and trust/greddy relocator. Just needs appropriate length of hose and you're off.
sounds like that might be a good idea, and I'm always about appropriate lengths of hose, price?
Buy my wheels and nos kit Pete
already got te37s so nit chasing rims... Yet...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
