Mugabetown - Whoretownin' At It's Worst.
Nah ill still be here unfortunately lol. Indooroopilly is nearly finished though. 2 years is too long for 1 project lol im never coming back here again once its finished
Is that the shamrock civil project? You with them or are you with a contractor?
Yeah Shamrock are on the job. They're doing all our civil/road works around the place. I'm not with Shamrock though I work for the main contractor Brookfield Multiplex.
Mike (Cadmoon) and Tony,
This is a photo I took of the duty free store on the ferry from Aland to Stockholm early this year
Prices are in Swedish Kroner (the first line item) and EUR - was quiet surprised that they were displayed like this considering its on boat and weather was atrocious (rocky was an understatement and even my stomach was turning while my poor wife was constantly throwing up for the first 2hrs).
they have some of the best stuff and rare stuff available in the Nordic countries - really wanted to get my hands on the cask of dreams Nordic oak edition :(
oh that looks nice, and cheaper than I expected actually.
Anyone want to take pity on a poor cripple and swap a couple of wheels over for me? :)
would if I could :mad:
can I borrow you're handicap pass?
Will be handy at busy supermarkets parking
I'll take a copy too
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
