Mugabetown - Whoretownin' At It's Worst.
Yeah. Doesn't matter about shaft play etc, they just need it to be in reasonably working order.
They just need the housings to not be f**ked, can even have all the blades missing.
So after an evening of pondering intercooler stuffs, i think i may have figured out the "but stock gtr cooler is good for 400kw's!" thing.
A few people have commented that they can't do back to back power runs on the dyno with them, so it seems like the stock one is plenty big enough of a heat sink for a little bit of a squirt, but then its way to oversaturated with heat to keep the job up afterwards.
The question is, is an ARC one going to be any better (only 10mm thicker, but better fin design?) or should I go for a bigger one down the road instead of hanging out for an ARC one...
I have an ARC. I have no heat soak issues. In a GTR coolers defence driving is quite different to being on a dyno in front of a fan. Intercooler would be low on my priority list
You're quite right, you'll be getting more airflow on the open road. However, there still has to be a limit to it, although that's going to be depending on a lot of factors. ambient temp, power, how much power is being used, how often, and for how long. I honestly don't know the answer and short of sticking a temp sensor into the outlet of the cooler i'm not sure i will know.
However, that being said, Sean did recommend a new cooler. And i'd like to get one now that will be good for 400kw down the road. So I dunno.
I'm running Chinese quality FMIC costing $300/$400
As Bunts said tis a lower priority than other mods on you're list
rule of thumb goes like so
300rwkw stock cooler ok
Anything over get a bigger cooler as the car / turbos will generate more heat that's what I used
Car was making 285kw's on 98, so I dam well hope its making over 300 on E85... I think i'll upgrade now.
I've been making up a bit of a spreadsheet of all things i want to do to the car, with prices and whatever other info I want to put in there, just so i can organise my head and jot down stuff so i don't forget it.
Shits expensive. UP to 25K already.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
