Mugabetown - Whoretownin' At It's Worst.
Back from tbar:
*Voucher purchased for mates 21st
*new set of gym shorts
*new set of nice shorts (like a reddy colour)
*new set of black skinny jeans
*redbull, scotch and drambuie purchases for 21st tonight
Set as ;)
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
