Mugabetown - Whoretownin' At It's Worst.
I'm more worried about the current location of the missing part of the cap.
who replaced the injectors?
I did the same thing btw - the broken plastic cap was just sitting on either side of where the injector plate manifold. Just check to see if any is there.
I don't believe it will be detrimental to your engines health either
Cover the windows and lights in paper...point...spray?
Easier said than done
Also Martin. Buy my old wheels. 18x8
17s would be better. Are they 4/5 stud? How much?
It's plastic, it'll disintegrate
