Mugabetown - Whoretownin' At It's Worst.
So you can look AWESOME!
And be all like "this totally matches the subtle undertones of this bottle of expensive Scotch that I can't pronounce" while everyone else just enjoys themselves not discussing tasting notes.
  • Like 1
I have been drinking lots of Blantons Bourbon lately. Have not even really thought about scotch. I got given some Jonny Walker that I need to find a way to drink though :(
mix it with coca cola
