Mugabetown - Whoretownin' At It's Worst.
Where have ye been ants?
bigger question is if he's bringing it to the next happylaps
I knew he was looking at one, wasn't certain if he had gone through with it.
Is it that greyish one?
Colour was one of the biggest selling points for me. Tough to find in TH1 at reasonable prices. Super excited to pick it up though.
Wont be able to make the June happy laps as its Christines bday that day so got other stuff organised :-) will be out to some in the future though and cruises etc
After a few the oil in the SS got so hot after only a few hot laps on the weekend I'm seriously looking into a cooler for it. What are the views on thermostats? Required or not, remembering that my car gets used as a daily.
I have 2 oil coolers in the shed looking for a new home ;)
Maybe they think a skyline with a turbo 4 cylinder would be able to keep up with an evo...
chrome finish - you know, for that subtle stealth look :D
Glow in the dark fluro green. Have actually seen that, there was one in the lot when I bought my first r33. I am leaning towards some form of dark green.
doooooo eeeeetttt.
Can see it already no. plates 'R Kermit'
