Mugabetown - Whoretownin' At It's Worst.
If you can convince the company that they need you and couldn't operate profitably without you, you have a winning argument. Hence $20k raise at the beginning of the year. ;-)
that is very rare, as it is seldom that one person could have such an impact on a business. Especially in the resources sector
If I amended that to 'as proftiably' would that be a more correct reflection? Of course, for this to occur, you would need to be at the top or very close to the top - especially within an arm of the business that closely related to sales.
it truly depends on the demographics of the business
Yes, if key senior personnel ie executives were to use their position as a bargaining chip to demand an increase in their remuneration package then it may work
Should it he reporting entity though - them auditors would be all over it
Especially the way the public now eyes deeply what how execs are remunerated
In a smaller sized business ie SME - most that are in a top position usually have the ability to influence everyone - making performance bonuses that much easier ;)
  • Like 1
Jawsome!
do tell how!
I was curious too so I did a little digging on the QLD/TMR site and I found this:
Moderately-Powered Vehicle Grounds
You may apply for a certifi cate of exemption if the car you wish to
drive was manufactured before 1 January 2010 and has:
• a supercharged or turbocharged engine, not diesel powered
• a power-to-weight ratio of not more than 125kW/tonne
• no other features of a HPV listed on this form.
You application must be supported by:
• a document published by the manufacturer verifying the
power-to-weight ratio, such as the owner’s manual or
information from the manufacturer’s website; or
• a specifi cation information test report.
A specifi cation information test report is issued by an automotive
service provider and must show:
• the name and address of the organisation(s) that conducted the
test(s)
• the date of the test(s)
• vehicle make, model, VIN/chassis number
• the vehicle’s kerb weight and maximum engine power
• details about the measuring system used to conduct the test,
for example, an engine dynamometer."
From what I've been able to find a stock 33 gts-t would have around 130ish kw/t if you're going off the factory engine and weight figures from nissan. That power to weight ratio wouldn't classify for an exemption however if you were to put the car on a weigh bridge and run it on a dyno it would most likely be under 125kw/t though. So I guess it's all up to which figures they take into account when doing the exemption.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
