Mugabetown - Whoretownin' At It's Worst.
I never said they weren't useful, just that they're a bad investment.
Several political parties...
Depends on how you value your time I guess! As a raw investment Yeah you always lose. But you have to factor in the cost/benefit too! If it was just a money factor no one would have one.
Political parties don't really care. There isn't enough to really care. They pretend to care so the borderline hippies, of which they're are many more get sucked in!
I dunno, if you had to walk or take public transport every where they would look pretty good as an investment in not having a shit life
that would very much depend on where you are located in Oz
For example if you in live Brisvegas or say Sydney I would forget about taking a car to drive there as the public transport system is pretty good IMO and it's not worth the city traffic wait
You'd still have a car (probably a shit box to get around outside the city)
Now you take the GC where the public transport is just epically atrocious you certainly would appreciate having you're own transport to get around
Irrespective, it's what you see as value to you that makes your investment
However, we all generally know that cars (aside from rare collectibles) result negative ROI
The only way to make decent power on your natro skyline is to build one of these babys: 0BWrtSC.jpg
Guaranteed 10rwkw and super sick sounding induction noise, it sometimes even flutters if you back off after hard acceleration ;)
Trolling around in the NA section lol
No point valuing cars interest financially. It's the emotional ROI.
Fair to say that anything that makes you money is nice to have, but doesn't give you a kick in life. Getting a kick will always empty the pocket.
Morning all. The epic busy-ness appears to be coming to an end. Should have the opportunity to regain some semblance of sanity shortly.... Maybe a couple of weeks or so when I'm on a flight overseas and work can't call or email me.
fluing Malaysian Airlines?
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
