Mugabetown - Whoretownin' At It's Worst.
One of mine went through a phase where she would pee in the toilet, if only they did everything in the toilet all the time I wouldn't need a litter tray.
Hahah that would be nice. I've gotta empty the litter boxes today and I'm not looking forward to it.
Meh, it's not that bad, takes max 5 mins and it's done (my cats litter anyway). Take like 2 mins to scoop it a couple of times a week. It's only bad when I have to do a full change at night and it's cold outside or when it's raining.
I hated Sydney. Clubs are shit. People are rude, there is a nice little Italian restaurant in the Rocks though.
Never been clubbing in Sydney and there is a good Italian restaurant on the Goldie :P or Griffith in NSW... First time I went out in QLD was to the Casino for F1 night...
What really? You've been here for like 2 years.
It's not that it takes long it's the fact that I cbf-ed lifting it into the bag then taking the bag outside.
Yeah really...
Lazy Chants!
cats cannot be taught by any human
cats rule their masters not the other way around
Mine do what they are told most of the time, I can even bath mine and walk them on a lead... Still getting used to the lead but they are pretty good...
its what they want you to think.
but they have an alternative motive
soon you will be wearing a lead :P
I didn't want to scare you
haha when I was awake this morning one of my cats could tell and she knows I won't open the bedroom door if she is meowing so she has learnt to mimic my other cat!!! I opened the door to see why she was making noise assuming it was Lily but it was actually Cleo and Lily was sound asleep! I was like you little turd! Couldn't help giving her a cuddle as points for trying :P
lol - them cats are up to no good
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
