Mugabetown - Whoretownin' At It's Worst.
Pretty crazy. Quite interesting. How've you been?
apart from catching an epic virus from hell I'm alright mate
I hate taking tine off work - but I couldn't even drive to the servo safely thus morning
That kinda told me to stay at home
Will prolly see dr tomorrow
I have a mountain of work to do in the office
How bout you?
Was the o/a trip a holiday?
What did you do there?
f*cking alarm or something on my neighbours shed has been going off all night. Sounds like a truck reversing. No sleep for me :( :( :(
That sucks McFly. Should record it and then play it through their window tonight. Although, they were probably going through the same agony and just didn't know how to fix it.
I have an air on unit bolted to the wall sitting 20cm from my head... Every day this swing. So it could be worse!
The gentle hum of an A/C unit has never been an impediment to my sleep before, so that would be far preferable.
P.S. HAPPY BIRTHDAY PETE!!!!!
aw, poor you
Man up Smartie
Get f*cked.
P.S. You need to get some of this: http://www.iflscience.com/space/space-whisky-return-earth
Go burn their shed down?
Tempting, so tempting.
They appeared to be not home/on holiday. No cars there and a big collection of junk mail.
Got jack of it eventually and called the cops. They said they couldn't do anything unless the shed was actually being broken into, but then she could hear it over the phone and decided to send a car round. They made it stop :) somehow
  • Like 2
The gentle hum of an A/C unit has never been an impediment for my sleep before, so that would be far preferable.
Get f*cked.
bah ha ha ha ha
Cops couldn't do anything
Called the wrong peeps there
You needed to call Mike
I'm going to have to respectfully disagree with you there. They made it stop, so obviously they could do something.
so did you see the cop car or did they tell you they stopped it?
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
