Mugabetown - Whoretownin' At It's Worst.
Morning folks. Had a nice meeting with an insurance asessor this morning. My 600km old car is getting a new rear bumper and new rear door, including all the bits that hang off it. No other damage. The door mounted spare acted like a big shock absorber! Lol
It's really hard to tell FTM
I still feel as bad
Just took two panadols rapids and about to take my first antibiotic for the day
Feel epically useless
Well I hope you feel better soon!
WTF dude what happened?
I am touching all the wood I can see to help change your stroke of bad luck mate
Yeah, Mel
I will get better
The pain in the kidney area is really unpleasant as well
Got hit in the back in a car park
That is ghey! I once had a lady reverse into the front of my car at a set of traffic lights... People are stupid...! :domokun:
At least it wasn't too much damage and they will hopefully get it fixed quickly for you (and do a good job of it).
Yeah, Mel
I will get better
Urgh yeah kidney pain always sucks - You have antibiotics now, 3 days you should be feeling a lot better ;)
Yeah, Mel
I will get better
Cheers mate.
Hope you feel better soon!
Faark mate that sucks! Not having much luck with that car aye? :(
Yeah not much luck so far. But it could have been worse the only metal effected is the rear door, which can just be unbolted and replaced.
I fecking hope so Mel
I intend to go to work tomorrow
But I'm so messed up I can't even recall when I put the oven on with the chicken for tonight's dinner :/
I had the same thing some old dude in an ancient laser just rolled back into my blue r32....TWICE!
Apparently they will have it for a max of 5 days starting Monday, so that's not so bad.
these things always take longer than initially stated.
But I do hope it's repaired speedily for you
See how you feel tomorrow otherwise you won't be doing yourself any favors!
Now you know what it is like to be blonde :P
Yeah this lady actually put it in reverse, her kid piped up and said that she did the same thing last week whilst she was apologising to me... It's not hard to keep your foot on the brake so you don't roll backwards but then again it's not hard to look for other traffic and people seem to struggle with that all the time!
Oh well that's good, pity you have to wait until Monday for it to start but at least they have given you a timeframe!
lol Mel
new parts will be in on Monday, car should be like a new one again by next Friday at the latest. Can't be too upset with that.
If it was Skyline overnight parts from Japan :P Granted Skyline probably would have come off worse than the new car did lol
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
    • What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled?   If you unplug the IACV, what rpm does the engine idle at?
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
