I'm looking to get some gauge holders for the dash and the sides because the look is cleaner but just want to know if anyone has experiences with universal ebay gauge holders. Like this one:
http://www.ebay.com.au/itm/400353979415?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Would it fit direct? Or will I need to modify it?
https://www.sau.com.au/forums/topic/431239-universal-gauge-holders/
would also like to know, but for 60mm gauges lol.
Woops. My bad. Theres one for 52mm somewhere I'm sure.
They should be fine. Very little or no modification needed
Cool. And how exactly do you mount them? 3M doube sided tape?
3m tape will be fine or screw it to the apilar
Alright great seems easy! Another question though.....how am I supposed to hide the wires because I'm thinking and looking around but can't seem to find anywhere to do it :S
  • 3 weeks later...
the one i bought was for left hand pillar. seller didn't specify and i didn't know lol.
oh well, lesson learnt.
Far out did the exact same thing as you, but then the seller said all I have to do is reject the item when it arrives and then they will exchange it, but that means I have to wait twice as long. Sucks, but consequences of a wrong decision.
