For Sale: R33 S2 front guards in white. Good condition will clean them down before sale. $80
R33 S2 Bonnet white good condition $150
R33 S1 Front drivers guard in gunmetal colour $40
R33 S1 Drivers headlight in ok condition, missing one tab $40
R33 S1 front bar indicator/fog light drivers side good condition $40
RB25 Pressure plate and clutch, bit worn but pressure plate would still be good $30
R32 full exhaust system 2.5 inch cat back with high flow cat and powerflow muffler $150
Prices are slightly negotiable within reason, Located on the Gold Coast. Pm me or contact on 0413900209.
https://www.sau.com.au/forums/topic/431298-r33-s1-and-s2-parts/
