Diy Calibration For A D90 (Or Any Non Af Fine Tune Capable Camera) Tried And Tested
Hi guys, just wanting to share this as I found it useful. Short version is I found this link, followed it and had success.
http://buckscorner.com/home/nikon-d90-autofocus-calibration/
Backstory.
I bought my missus a D90 a few years back when it was considered a good camera.
On a holiday we had the camera in the boot of the car (in a decent lowerpro bag) but somehow it got lose of where it was packed and it must have taken a fairly solid knock.
The 18-55mm kit lens then started showing some binding issues on the focus ring and pics out of the camera didn't seem as crisp, I assumed it was the damaged lens and as the other lens was a 70-300 it was hard to test them back to back to confirm.
I recently got jack of struggling with the 18-55 and its lack of low light capability (f3.5 at best) and how it was costing me shots of our new bub. So I bought a 35mm 1.8G DX for it and was disappointed that shots still looked average.
I'd suspected the camera may be at fault too so started doing some reading.
As there's no place locally to calibrate lenses I knew I'd have to send it to Melbourne so thought I might as well have a go myself and if I got it wrong it was already being sent away.
I ran through the focus tests and found it was back focusing noticeably. I made tiny adjustments on the screws as per the article and tried my best to mimic those changes on each of the 3 screws. Took about an hour or so.
My result was quite good, faster focusing and much sharper images. I would say that I think it may not be 100% as I suspect that there's some "soft" focus around the edges (at higher F stops so it's not a DOF issue) so the camera may be calibrated anyway, but in the meantime, until I can get down to Melbourne, I'm much happier with the shots coming out of the camera, as is my partner (which is probably even more important...).
Keep in mind this is only useful for Cameras that dont have AF fine tune adjustments built in, so if you have a D7000 or something you can make adjustments from the config menu and do not need to be fiddling with screws.
Great find,
Definitely going to attempt this on my D90, my shots where coming out soft as well. I thought it was time to upgrade cameras...
Maybe a last hurrrah before that happens :D
Everything I've read suggest back focus is a common issue on D90s.
Further down in the comments, on guy explains which direction to turn depending on if you've got front or back focus issues.
Even if you do end up with a new camera, a second body could be handy if it's working well :)
Good luck.
Edited by ActionDan
    • Yeah, you need to do it properly. You need to start out slow and gentle, ramping it up until they are good and hot, but not cooking, then roll off the other side (instead of letting them cool down quick).
    • I think yeah less hot fuel dumping into the top of the tank that wants to evaporate easily, fewer connections/hoses for permeation. Something like that. Also lower cost/easier production. Even my 2000 LS400/Celsior is a deadhead system. A single fuel hose to the fuel rails which have pulsation dampers attached and no return line.
    • I might do a few more high temp bed ins as described here.  I have a nice quiet 80kph road right near me.  How To Bed-In Your EBC Brakes For Street Or Track Use - EBC Brakes https://share.google/AjnOTILXoiqQnLu8p
    • I did a few 80-0 stomps. I then just rode the brakes while I applied throttle for a while to get them nice and hot. I live on a big hill and have been down it a few times also with stomps and brake riding.
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
