Diy Calibration For A D90 (Or Any Non Af Fine Tune Capable Camera) Tried And Tested
Hi guys, just wanting to share this as I found it useful. Short version is I found this link, followed it and had success.
http://buckscorner.com/home/nikon-d90-autofocus-calibration/
Backstory.
I bought my missus a D90 a few years back when it was considered a good camera.
On a holiday we had the camera in the boot of the car (in a decent lowerpro bag) but somehow it got lose of where it was packed and it must have taken a fairly solid knock.
The 18-55mm kit lens then started showing some binding issues on the focus ring and pics out of the camera didn't seem as crisp, I assumed it was the damaged lens and as the other lens was a 70-300 it was hard to test them back to back to confirm.
I recently got jack of struggling with the 18-55 and its lack of low light capability (f3.5 at best) and how it was costing me shots of our new bub. So I bought a 35mm 1.8G DX for it and was disappointed that shots still looked average.
I'd suspected the camera may be at fault too so started doing some reading.
As there's no place locally to calibrate lenses I knew I'd have to send it to Melbourne so thought I might as well have a go myself and if I got it wrong it was already being sent away.
I ran through the focus tests and found it was back focusing noticeably. I made tiny adjustments on the screws as per the article and tried my best to mimic those changes on each of the 3 screws. Took about an hour or so.
My result was quite good, faster focusing and much sharper images. I would say that I think it may not be 100% as I suspect that there's some "soft" focus around the edges (at higher F stops so it's not a DOF issue) so the camera may be calibrated anyway, but in the meantime, until I can get down to Melbourne, I'm much happier with the shots coming out of the camera, as is my partner (which is probably even more important...).
Keep in mind this is only useful for Cameras that dont have AF fine tune adjustments built in, so if you have a D7000 or something you can make adjustments from the config menu and do not need to be fiddling with screws.
Great find,
Definitely going to attempt this on my D90, my shots where coming out soft as well. I thought it was time to upgrade cameras...
Maybe a last hurrrah before that happens :D
Everything I've read suggest back focus is a common issue on D90s.
Further down in the comments, on guy explains which direction to turn depending on if you've got front or back focus issues.
Even if you do end up with a new camera, a second body could be handy if it's working well :)
Good luck.
Edited by ActionDan
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
