Just a quick question
does Mobil Synergy 8000 contain ethanol? or BP Ultimate for that matter?
I asked my mate the other day what fuel he uses and he says Optimax is the best. When I said Mobil Synergy 8000 and BP Ultimate are better he clicked it at me and said that they contain ethanol. He is the type of guy who hates being wrong and will go to the other side of the world just to prove you wrong.
https://www.sau.com.au/forums/topic/43149-ethanol-in-fuel/
i think it comes down to opinion, i haven't done any tests, but from what i've read/heard optimax is 95ron engineered up to 98ron, and only has a lifespan at 98ron for 2 weeks
where as synergy and ultimate are manufactured as 98ron, and last longer than 2weeks..
but as long as your car doesn't ping, shouldn't make a differnece
https://www.sau.com.au/forums/topic/43149-ethanol-in-fuel/#findComment-880969
they arent supposed to contain ethanol. There were some cases a while back where ethanol was found in some fuels, but its illegal or something coz it can cause damage? so id say none of it has ethanol at present.
the 8000 and ultimate 98 are both quality fuels, your pretty safe using them. Better than using optimax in my opinion. I tried it for the first time when i took my car to NSW and the car just didnt want to rev out. I put it down to a bad batch of optimax, as i had to use some a while ago and it was fine. but that said, i have optimax in there now, been sitting there about a week and a half, and now i have the same problem, it pops and wont rev out, so i wont be using it again unless i have to.
https://www.sau.com.au/forums/topic/43149-ethanol-in-fuel/#findComment-881081
OK just did a bit more research.
(The things you can learn after midnight!)
BP did do a short trial with ethanol in QLD in 2002.
This little snippet has all the answers:
As no BP fuel contains ethanol they do not need to state anything on the pump. Mobil and shell are the same. Shell has by choice decided to label their pumps anyway regardless of the fact their fuel contains no ethanol and they do not legally have to do it.
[EDIT]
All that aside, I wouldn't even think of touching OPTIMAX, my car is NA, and if i use optimax it pings... i cant imagine the sort of damage it could cause to a turbo car.
https://www.sau.com.au/forums/topic/43149-ethanol-in-fuel/#findComment-881107
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
