What kind of punishment can you put the stock drivetrain through before upgrading? I have a R33 with an auto. My HP goal is 450-500. Motor is built for it and just recently installed it back into the car. Haven't started it yet cause waiting on a few more parts to come in the mail. I've been so wrapped up with other stuff that I just realized that I haven't touch the drivetrain. Wouldn't mind going to a manual but running out of time for this to debut at a show and sourcing parts here in the US is difficult. (car must be driven 600 miles to attend) Can the auto transmission, torque convertor, drive shaft, rear diff, etc handle this power? I've attached the vin plate for better insight. post-116132-13786745979762_thumb.jpg
The RB25DET gearbox can easily handle the power (really, the torque) levels you're talking about. But of course it is better to do it on one that is either new or freshened than to do it on one with worn selectors, synchros and all that jazz. The main components are big and heavy though, so they can certainly carry some mechanical load.
The diff is big and stron, the tailshaft and driveshafts are all strong. But the same things applies. Sloppy old CVs will always give before good condition ones will.
Word is that the stock bottom end of the RB blocks handle almost 1000hp. That's what I guess I'm asking. What kind of power the stock RB gearbox auto and manual would hold along with the rest of the drivetrain.... Has people snapped axles or C/V's?
Thanks! I was typing and didn't see this response yet.
Do they make new gearboxes? I was thinking on ordering a used one if I come back with the car and doing a refresh on it. I'd love to do a ratchet trans but putting that kind of money in a transmission is hard to ask for it back.
New RB25 boxes are available for about 3 grand here in Oz. Worst case you could order one from here, but I'm sure that Jap sourced or possibly US sourced alternatives should exist.
1000HP should not be attempted on RB blocks without a partial grout fill. They will do it, but they will end up splitting. Grout filling is cheap insurance if you're planning to go mental on power levels.
If you are planning to go that far, then you have a lot of reading to catch up on.
I don't recognize that term grout fill?
People snap axles at the drags with 700hp or less but Rips put over 1000hp through a stock front and rear end (but with a monster powerglide/transfer box)
Is that like installing thicker cylinder sleeves? If so, I understand that.
No - imagine taking out the frost plugs and pouring concrete in to the block until its half full.
Here ya go - apparently Yanks call it Hard Blok
http://www.jegs.com/webapp/wcs/stores/servlet/KeywordSearchCmd?storeId=10001&catalogId=10002&langId=-1&Ntk=all&Jnar=0&Ne=1%2B2%2B3%2B13%2B1147708&searchTerm=hardblok
There's quite a few options - e.g. OS Giken from Japan PPG dogbox from Aus Autosalon Yokohama from Japan and HKS dog box H pattern or sequential like this: http://www.trademe.co.nz/motors/car-parts-accessories/nissan/gearboxes/auction-635181453.htm
and more...
and more...
Yeah, look at the price tag. $15k isn't exactly cost efficient. Wouldn't mind spending $4k on a trans but not $15k. I couldn't ask $15k or more on an upgrade like that. There's a reasonable percentage you can ask for when selling your car when heavily modded. But I must admit, that HKS kit would be a dream to have.
Yes. I know that term. I steer far from that. Heat dissipation and heat soak become issues
No they don't. You don't have to fill the whole water gallery. 1/4 fill is sufficient to re-inforce the weak part of the block.
This is one of the reasons I said you have a lot of reading to catch up on.
I'm not going that route. No reason to have that much power in a Skyline. 500 is plenty. If i wanted more, I'd do a LS swap. Thanks for the info though. It's helpful. Just wondering about the drivetrain and its reliability.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
