I've currently got a walbro 255 intank pump and my cars going to run a flex set up shortly so ill be looking to change the pump. For a car running between 400-450 rwhp is the walbro e85 pumps over kill for that power level? I hear some of use guys run into fuel over heating problems on e85 and having to run a fuel cooler set up and some of use running variable fuel pump speed controllers to try help the situation. Just seeing if the aeromotive 340 pump will be suitable for my power level and be safe? Cheers
https://www.sau.com.au/forums/topic/431929-aeromotive-340l-intank-pump/
That pump would be running a pretty high duty cycle at 450hp on e85, personally I'd try something bigger.
Have you asked your tuner? They will have a pretty good idea
Edited by Blackkers
The 255's are a good pump, and handle the e85 perfectly imo, perhaps it would almost make your power. I can't say the same for the Deatschwerks 300 pump, I had to replace a seized one the other day. Hopefully the Aeromotive gives you a better run.
Personally I would go for the $200 Walbro 460L e85 pump straight up. At least you know they will warrant any failures if you run ethanol as it's designed for it specifically.
Just this one Scotty? Have you heard of any more of these failing? Hoping it was a one off as I have a 300 ready to go on, heard they were a good unit.
Yes, only the one failure. It lasted 500k's or so over a few months on ethanol, finally seizing after getting noisy for a week and left him broken down on the freeway. I took it back today so we shall see how good their 3 year warranty really is.
Tried ringing VPW today to see how far away the DW400 ethanol pump is as they don't have stock still, they didn't answer as usual. Why it's listed in the catalogue is anyones guess. Hopefully it is the same Walbro 255 body size as the 460L won't fit in the stagea pump holder.
To fail in 500k's it must have had a major fault in the unit. The DW300 is listed as ethanol compatible so surely they must stand by there warranty as a random dud pump, unless there was contaminants which you would have seen anyway. One of the reasons I bought mine is because I figured it would fit in the Stagea holder. I'd be interested to here how you go either way, if the new 400 is the same body size that could be a good thing.
sounds more than good enough for my needs, how did you go about modifying the factory fuel lid for larger wires to the pump? or did you just run larger wires to the factory plug on the fuel lid?
some of the guys end up melting connectors on the fuel lid after fitting the walbro e85 pump with it drawing to much current.
Yes, of course. I have fitted 5 or 6 to various cars since they were released, with no issues other than this one. Unfortunately getting warranty is subject to them agreeing there was an issue, $10 says they find "crud' in the pump, even though it had a sock firmly attached. :/
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
