Hi Guys and Gals,
Name is Nate and I've been a lurker for a while, so thought I better introduce myself.
Filled in my application a few weeks ago so will be good to meet some of you !
I dont drive a skyline.....yet :P but own a 2011 STI Spec R, also have my Cams License and trying to get my officials license so hopefully will see you all at some of the events soon or am more than willing to help out if needed in any of the events :)
Cheers!
https://www.sau.com.au/forums/topic/432018-howdy/
welcome.
post pics of current ride.
were not just skyline lovers, but car lovers in general.
hope you enjoy the forum.
re:whoretown...
if you get easily offended, best to stay clear.
all is said in jest, bit some take it the wrong way.
https://www.sau.com.au/forums/topic/432018-howdy/#findComment-7025150
    • I was just driving into work and while on my drive, I went to accelerate and noticed the car would sputter/hesitate and I’d hear a few pops from the exhaust before it started going faster. Then I also noticed that when I push my clutch in, the car would die. This all started happening today. Any ideas?
    • That is a lovely Volvo, just saying. Yes I should have got an 260RS when they were cheap. I do regret now.
    • ^ lots of good points made above. The thing is, "aggressive" or "flush" fitment is relative depending on how much you have been influenced by social media. My starting point is always "look at the Nismo RWD specs". That is where you should start, then start measuring as GTSBoy as sort of mentioned, because every car will be slightly different. My 8.5"+35/9.5+38 will not be "flush" enough for you because you want more "pumped" look, which is why you measure. Tyre sizes and brand/models also make a difference. Some tyres are more chunky/square, some are more rounded. That means you could get away with more aggressive offsets without rubbing. But then it also depends on your ride height. Also depends on how much your car copped damage before being shipped from Japan. So it goes back to measuring your car yourself and determining what can work. Those Nismo specs are used bacause it's a safe spec for standard car (suspension. body) with chunky tyres. But then I put 265/35 wide tyres on R34 GT-R wheels, and currently run 285/30 tyres on 18x10 wheels.
    • Sounds pretty awesome. I recommend creating a new build thread and posting all your goodness in there.
