hi guys
i am having a shocker - i brought a HICAS kit of a mate wich cam with rods attached thinking this would be easy pull hicas out as a hole then put the lock bar in as one
but i have all of it off apart from the rods i can not get the over the bolt - how are they attached? is it easy change?
as you can see it the pic with the lock kit is hard to separate as i dont have a tool to fit - my shiftier is to wide it hits both sides..
basically i wanna take rods off and fit it as one-
https://www.sau.com.au/forums/topic/432022-amateur/
The original rear tie rod end is on a ball joint at the outer. You have to split the joint off the taper, then, assuming the kit you bought doesn't just fit back to the tapers, you need to get the ball joints pressed out of the knuckle and bushes to suit the new arms pressed in. Perhaps you'd best show us some photos of the outer ends of the new arms.
https://www.sau.com.au/forums/topic/432022-amateur/#findComment-7025829
OK, I read what you wrote more carefully and see that you can't split it at the inner end because your shifter hits both flats. If you could split it you'd keep your existing rods connected to the knuckles. If you can't split it you'll take your existing rods off with your HICAS rack and use the rods that came with the lockbar.
I'm now assuming that both sets of rods are the same so it won't make much difference either way. So if you have to split the rod ends off the ball joints, then do so. If you really prefer to keep your existing rods, then perhaps you need to make a spanner up out of some flat steel. You just need to angle grind in a notch into a bit of steel that is thick and deep enough to be strong, but not so thick that it causes the same problem as your shifter has.
Otherwise, just go down to the tool shop and buy a suitable spanner or two. Jobs like these are excuses to buy nice tools.
https://www.sau.com.au/forums/topic/432022-amateur/#findComment-7026352
    • Keeping in mind that for most people this is a week to month long job!
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
    • What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled?   If you unplug the IACV, what rpm does the engine idle at?
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
