If you have ever dabbled with aftermarket bars for the V35 you will come to realise (as I did) that our cars are VERY low, and fibreglass bars break quite easily and are an endless source of frustration.
I finally bit the bullet and ordered one of these awesome copy Nismo urethane bars out of the USA. Then when I got a postage quote of $1,250 I nearly died. So I bought a few to make the postage cost effective, and subsequently have spares for sale.
They are imho superior to the factory Nismo items, as these are made of urethane (in fact they almost feel like rubber), whereas the genuine bars are fibreglass and break with a decent crunch.
The fit is near enough to perfect, and indicators fit near enough to perfect also (unlike the other fg bar I have had, the fit of which was AWFUL).
They are located in Adelaide, but I can ship if required. I would imagine shipping would be around $100-$150 within Aus depending on destination. Weight is around 10kg, but obviously cubic weight is much higher.
$1.000 each (which if you have ever imported one yourself you will realise is a great deal - and saves you the headaches importing them and the issues and costs with customs I won't go into!).
These are THE bars for V35s in my opinion, and given they are urethane and almost unbreakable, may be the last bar you ever buy for your V35.
Yeah but look at it as an investment - if you went out and bought a fibreglass bar for say $350 and had it painted $250-$300, you would break it in around a year and need a new one (like I did). Instead, buy one of these for $900, have it painted $250-$300 and it should last you for the life of the car :) ... plus the finish on them isn't bad - you could easily run around with it fitted and unpainted until you could afford to get it painted :)
  • 3 weeks later...
Here's a pic of one trial fitted to my V35 (unpainted - and needs a bit to more work to get perfect - will be 100% perfect once painted and refit). Getting it painted shortly.
  • Like 1
Here's a pic of one fitted (unpainted) to my V35. Getting it painted shortly.
Nice. It looks like a great fit - but now I just want your lights... :wub:
Stuart
  • 1 month later...
I would really love to have a nismo bumper but i have an oem front with new lip on now. Furthermore, someone donated 2 x GTR fronts to me..... so it would be a waste not to try on the spares before buying a new one. First world problems.... sigh. Btw how much is shipping to NSW anyway? Who knows -> A magical pot of gold might be at the end of some rainbow waiting for me.
Edited by SuperDry2013
Hey Superdry, did u and your cousin / brother buy the gt Wing carbon + set of wheels and tires from me ? I think Im the one who donated the GTR front. did u figure out to make some use of them. pardon me if im wrong :D
Hmm sounds like a matching story. My cousin just said he had a surprise for me one day. The bumpers are sitting in storage for now until we have time for fitment. Its a little "Ricer" but i'll give it a try. How come you did not want the bumper?
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
    • It sounds like you want what the Toyota Landcruisers have for their roof racks. Wanna know what you end up with? Rust holes in the roof, and water everywhere...
    • Discovered today that if I select reverse first and take my foot off the brake, then select drive, the drive indicator light works and so does the tiptronic gear indicator.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Does anyone here have any ideas?   Cheers guys
