I have for sale a Supertech RB25 Solid Lifter Conversion Kit
It contains:
24 Supertech Valves - +1mm
24 Supertech Solid Lifters
24 Double Valve Springs - 83lbs @ 35mm Max lift 14.30mm
24 Spring Seats
24 Titanium Retainers
The kit is brand new and never used. All the valves are still in their packets except 1 that I took out for inspection. All the other parts are still enclosed how they came from the supplier in airtight lock bags
$1800 for the kit
  • 4 weeks later...
I did my homework on the supertech valve train some months ago, off memory they only make one type of dual valve spring, which has a rate and height for their 1mm oversize valves and theyre solid lifters etc. however they have different composite valve's etc. can you elaborate a little more on exactly what they are?
Reason is so that i know what i am getting for my money and, so i can redo my homework on the price :yes: then throw you a reasonable offer.
  • 3 weeks later...
Hi BJ,
The part number on the packets of the valves are NIVI-1052-SL and NIVN-1052-SL. Supertech list these as Black nitrided for intake and Inconel for exhaust.
Link here for information: http://www.supertechperformance.com/catalog?mk=8&ca=328&en=76
It's the only valve they do for this application that I'm aware of. Retail on this kit is $2200-2400
  • 1 month later...
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
    • Probably. I take it that they are also mentioned to be for R34 Skyline? For example.... RDA has that part as RDA7957. I have the dimpled and slotted version of that on my car https://www.ebay.com.au/itm/285518478694?srsltid=AfmBOopKxMuAFpsxZJdB1cam4D5RAj1f9yJyOttPZLAwXVNCOiwlhrIy This is DBA's top one piece equivalent https://www.ebay.com.au/itm/364246686631?srsltid=AfmBOorbb0XHQgqTvZLgQPhg70nqJtGvdojKnugum3O2LFSr2h-obp8D
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
