nice one geeza! hehhe pics pics pics... oh and more details, can't just say supercharged V35 and leave it at that... what supercharger, what mods?
oh and welcome aboard, may not be an RB, but you wear the SKYLINE badge as proudly as we do so who cares.
https://www.sau.com.au/forums/topic/43250-newbe/#findComment-882843
thanx for the welcome... nice
car standard except ati procharger (7lb pulley) centrifugal s/c and intercooler. mods to do this year = nismo sway bars and springs/coilovers (drop it an inch or so) will post picture link tomorrow.....
https://www.sau.com.au/forums/topic/43250-newbe/#findComment-882957
I'm now officially in the process of getting a V35 Skyline 350GT Coupe... I luv em.
i've done 100k miles in r33 & 34's (stage 1 mods) and although they are completely different, i don't regret moving on... you have to drive these mothers to appreciate em.
yes I'll probabley rot in hell for saying it... i know i know
https://www.sau.com.au/forums/topic/43250-newbe/#findComment-882959
as soon as Nissan Australia finalise its decision on whether it will bring the V35 into the country or not, enabling grey import compliancers to apply for plates.
Actually they could now seeing that Nissan isn't bringing them in, but they will have to bring one in for testing and approval at their cost, and if Nissan Australia decides that its gonna bring em in on volume then the compliancer loses out.
https://www.sau.com.au/forums/topic/43250-newbe/#findComment-883015
are you trying to make us jealous rezzeh :) make sure its kitted out to the max too... impul everything :rant:
Shall do... but I'm only gonna do Impul filter and steerring wheel, the kit will be "R-Spec Datasystem" y'know the one? Oh and some gunmetal Work Emotion CR Kai's...
https://www.sau.com.au/forums/topic/43250-newbe/#findComment-883026
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
