Hi Guys!
After a long time with it I've decided to put up my GTR for sale :(
Keeping it short, provided a list of parts below and if you have any questions or queries feel free to contact me and I'll provide more information.
1999 Nissan Skyline R34 GTR V-Spec - $69k ono.
- 51,250kms as of post
- currently has 440rwkw @ 22psi on 98ron (engine would have roughly 5k kms on it)
- located in Melbourne, Victoria
- rego plates not included in that price, if interested we can work something out
Contact me via PM for more details
Parts
  • Crank Shaft Billet 2.6
  • Tomei 280 Degree Pro Cams with Dual Valve springs and Retainers
  • Tomei Pistons
  • Tomei Conrods
  • ARP Head Studs and Main Studs
  • N1 Oil Pump and Water Pump
  • Holinger 6 Speed Sequential Gearbox
  • OS Giken Quad Plate Clutch
  • GT3540r with twin 50mm Turbo Smart Gates (custom front and dump pipes)
  • 4inch Exhaust
  • Motec m800
  • Motec cdi1
  • Motec E888 Expander
  • 1000c Sard Injectors
  • Sard Fuel Pressure Regulator
  • Tomei Fuel Rail
  • Hypertune Single Throttle Intake Manifold
  • Volk Racing TE37 Wheel 18x10.5
  • Custom Muffler
  • ATI Harmonic Balancer
  • Twin 044 Fuel Pumps
  • Custom Surge Tank
  • Hi Octane Racing Plenum
  • Mercury Ignition Coils
  • Electric Vacuum Pump Brake Booster
  • Tomei Cam Gears
  • Greddy Water Pump and Power Steering Pulleys
  • Custom Catch Can
  • PWR Twin Core Radiator
  • Speedflow fittings
  • Braided Fuel Lines
Photos can be found below attached
https://www.sau.com.au/forums/topic/432589-99-r34-gtr-v-spec/
Awesome specs.
Who built the engine?
And why use an N1 oil pump?
Thanks mate, took a lot of time to get it to the stage it is at.
The engine was built over 3 years ago by a guy named Benny and since then a friend and I have been working on it.
Back then he listed it as a N1 Pump (I've got a feeling it really is a Tomei Oil Pump, but don't want to give any false information as the list of parts used I received had the N1 listed). Don't know why it was used back then, guess it was his preffered choice, I know it's not the best of choices.
  • 1 month later...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
