I'm in the final stages of my oil system and wanted peoples advice/ideas
Ill be running an external single stage pump
Sump is going to be a custom alloy baffled and high volume setup that iv designed myself it will have fittings for oil pump, catch can breather, front oil return from head, rear oil return from head
Vct will be blocked off with 1.2 restrictors in the block and drilled out returns in the block
Oil cooler is currently set up from factory oil filter but that was where I was going to put the line for the oil pump is that the best place to put it?
engine is a rb25/30
https://www.sau.com.au/forums/topic/432675-oil-system-setup/
I'm going to have a mesh cage kind of thing around the pickup pipe and a micron filter in the fitting and iv got a filter relocation kit in the cooler line would that be enough?
I'm mostly worried about the best place to plumb the oil back into the motor from the pump at the moment
Not sure if this really is an issue or not, as it's not my first hand knowledge, but when talking to my machinist when welding up my vct feed, he mentioned pre neo rb25s use that feed to lube the front cam bearing and that he has seen a bearing destroyed as a result of just blocking up the feed. (neo head vct is different) If you look at this thread http://www.skylinesaustralia.com/forums/topic/251669-rb2530-rb30det-vvt-internal-oil-control/ the photos half way down show what I am talking about.
I was planing on just welding the port on the bitten of the head were the oil exits and grub screwing the solenoid hole from what I understand the cam bearings will still get oil from the head it just won't be able to get out the bottom if that makes sense
Well if it was me I would be checking tht after you weld it it does actually get oil supplied to the front bearing, easy to do with some compressed air. An easy check to prevent a serious problem, and if it doesnt get lube drill out the plug like in the thread, easy fixed!
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
