Got a few surplus parts here plus some stuff i've removed from my own car
Pickup in Sydney or I can post out most items:
1. R33 GTR front & rear seats (rears not pictured). Sensational condition, no burns/tears/holes = $1000 pickup only
2. Set of 18x9.5" ROTA Grid wheels at tyres. Great condition, one of the wheels has some light gutter marks but the others have basically none - $1000 ono
All are 5x114.3, 18x9.5" +38 offset. Tyres are 235/40 Federal ss595 - rears have some camber wear and are probably not roadworthy - fronts have a little bit left at maybe 20% above tread markers
3. Full set of slotted rotors to suit R33 Gts-t (rears will fit R32 as well) Almost brand new- fronts still 30mm thick, rears still 18mm - $300 for the set
4. Greddy style RB25 intake plenum, polished/silver. Includes 80mm throttle body, TPS, AAC valve, etc - $400 ono
post-35556-0-41794800-1381036719_thumb.jpg post-35556-0-80402400-1381036746_thumb.jpg
5. RB25 Stainless steel T3 flanged high mount exh manifold. Includes 38mm adjustable external wastegate + screamer pipe. Great condition - $300 ono
post-35556-0-57790400-1381036846_thumb.jpg post-35556-0-93035300-1381036855_thumb.jpg
6. Blitz Dual SBC Spec-S electronic boost controller. Includes solenoid, all wiring looms - $250
7. Bolt on SRI wheel spacers - 5x 114.3 - 20mm and 15mm - $75/pair
post-35556-0-96010000-1381036878_thumb.jpg post-35556-0-05420000-1381036923_thumb.jpg
8. 3" catback exhaust system. Front section is X-force, rear is a stainless a-spec straight through dual tip - looked great on the car - $200 pickup only
post-35556-0-02917100-1381037689_thumb.jpg post-35556-0-31014100-1381037747_thumb.jpg
9. Walbro GSS-342 500HP fuel pump in R33 cradle, drops straight in - $80
10. Pair of Avantek 18x8" wheels & tyres. Wheels are in sensational condition, basically no scrapes/damage at all - $200 ono
One of the tyres is as new has about ~90% read, the other one has some camber wear and is probably not roadworthy
How much delivered to the Gold Coast?20mm wheel spacers. 0414963402
PM sent
$90 delivered, PM sent
I'm keen on the exhaust what area u in
Pm sent !
Best price on plenum?
I can probably do it for $400 delivered depending on where you are. Pm sent
keen on the slotted rotors, whats your best price delivered to gold coast 4208??
cheers
PM sent
would you pull the tires off the rots?
If the price is right, PM sent
Would you sell the front seats alone? Rail included?
Just looking to sell as a complete set at the moment, sorry
Cheers
GTR front seats sold (rears still for sale - $200)
Greddy intake & highmount manifold sold
ROTA wheels, Blitz EBC, spacers, fuel pump still for sale
hey mate Im after the exhaust manifold the wheel spacers and the fuel pump can you pm me with your best price on all three
cheers,
VJ
just so you know, i was enquiring about the rotas but the offsets dont suit my stag after doing some reasearch,
great price for great looking wheels though,
i highly recomend someone buying them.
the guy who may be buying my 34 may be interested but i will see if he buys the car first. they would suit it pirfectly
gl with sale
Blitz EBC sold
cheers,
VJ
PM sent
gl with sale
cheers :thumbsup:
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
