Hi guys,
Since purchasing my new R34 GT-T I need to get rid of my current FTO.
1995 Mitsubishi FTO GR Limited Edition.
cp5057633871094873097.jpg?height=700&asp
Price includes RWC and Rego until Jan 2014.
- Fresh oil & coolant change (oil changed every 6,000kms)
- Genuine FTO Version R front strut brace
- Lowered suspension with pedders front springs & king springs rear
- EBC Red Stuff front brake pads
- Denso Iridium spark plugs with Magnecor leads (changed 15,000km ago)
- Yokohama C drive front tyres changed 10,000kms ago (rear tyres plenty of tred)
- K&N pod filter
- Factory sports exhaust
- Hydraulic lifters changed recently (no tapping noise like most FTO's)
- Always filled up with 95/98 petrol
- Cold air conditioning working
- Rear engine mount changed recently
- New battery only 3 months old
- Always taken care of, never had any major issues as it was serviced regularly
- No oil leaks like a lot of cheaper FTO's
+ a few extra upgrades
The only problem is one of the timing pulleys is starting to wear out causing a bit of noise, but I will include the full timing belt kit with it. The clear coat on some of the roof is also peeling a bit.
The add can be found here:
http://www.carsales.com.au/private/details/Mitsubishi-FTO-1995/SSE-AD-2350985/?Cr=0&sdmvc=1
I've listed it for $3,599, but will do a special price for any SAU members :)
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
