Hp Pavilion Dv6-6C20Tx 15" I7 2670Qm 2.2/3.1Ghz 8Gb Ram 640Gb Ati Hd 7690M-2Gb
selling my laptop i dont use anymore.
reason i bought it was to play games while staying at my gfs house.
bought it for 1200 from harvey norman same week as diablo 3 came out.
has a new battery as the original one died just before warranty ended.
everything works fine runs most games well enough.
comes with laptop bag and razor mouse pad if wanted.
looking to get $500 for it.
or swap for a 144hz gaming monitor depending on brand cash either way
  • 5 weeks later...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
