Harro,
Just stuff lying around the garage, all parts are used.
Factory Steering Rack Ends/Tie Rods $10
Factory Steering Tie Rod Ends $10
Factory SMIC $50
Factory SMIC piping $50
Factory Cross over pipe & BOV $50
Factory Down pipe $20
Factory Dump pipe $20
Factory Catalytic Converter $50
Factory O2 sensor $10
Factory Mint Handbrake OEM boot $10
Factory HICAS unit $20
Factory Passenger side kick panel, 1x flare clip broken $5
Factory Stock R33 Rims x4 (tyres might not pass an inspection) $100
Bendix DB1170 Front Brake Pads (Near New) - "Guaranteed Race Car Like Squeal" $30
Blitz 60mm Gauge Holder $5
Subframe Lock Collars - Blue in Colour, full set (8 pieces) $40
Contacts: PM or Reply Here
Location: Canley Vale, NSW, 2166 (AH) OR Milsons Point, NSW, 2061 (BH)
Will post some items, but prefer pick-up. Will give discount on bulk purchases, and yes I accept beer as payment also (no VB, Fosters, XXXX, etc..)
Would you post to sa? If so how much would you want for them sent?
yeah and $20 ontop would cover it
Schizzle for sale... help me fund mah modz :)
Factory SMIC $50
Factory R33 GTS-t Manual Radiator, working removed for upgrade $40
yezzzzz
Sold:
Available:
Factory SMIC $50
Sold:
Available:
Factory SMIC $50
Sold:
Available:
Factory SMIC $50
Friday bump this schizzle...
You know I'm negotiable right? How about give me 3x slabs of Blonde and you can take everything remaining in this thread.
Sold:
Available:
Factory SMIC $50
Some updates, tyres fell through.
Take everything available here for $150 or 3x slabs of Blonde.
Sold:
Available:
Factory SMIC $50
Factory HICAS unit $10
Factory Stock R33 Rims x4 (tyres might not pass an inspection) $80
Bendix DB1170 Front Brake Pads (Near New) - "Guaranteed Race Car Like Squeal" $20
Fully Sick Gearboot & Handbrake Boot in black leather with purple Stitching $10
Sold:
Binned:
Available:
Factory SMIC $50
Hey bud
I'm interested in the dump pipe, down pipe and the bov (if you're willing to seperate it)
Though i'd need it posted to vic.
I'll pm anyways
  • 3 weeks later...
Sold:
Binned:
Available:
Factory SMIC $50
  • 1 month later...
Available:
Factory SMIC $50
Superlow Rear Springs R32/R33/R34 GTS-t/GT-t $40
Sold:
Binned:
Available:
Factory SMIC $50
Factory Blow Off Valve $30
Factory R33 GTS-t Manual Radiator, working removed for upgrade $20
Sold:
Factory Cross over pipe $30
Binned:
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
