post-65459-0-96578500-1381407394_thumb.jpg550RWHP - 340KW AT ALL 4 R32 GTR selling my R32 GTR very quick car, reliable, and has further potential. the engine was rebuilt by previous owner, with all work done by ADVAN perfomance in sydney, and i have had about $15000 worth of work done at CNJ motorsport in underwood QLD. i have receipts for all of the work i have had done and from the previous owner. mods include. engine - crank balanced and micro polished arp rod bolts rods unknown? trust 8.6:1 compression forged pistons upgraded valve springs trust 272 deg cams trust adjustable cam gears trust 8L sump extension and 26 row oil cooler and relocated oil filter custom catch can alloy radiator full trust T78-33D Turbo kit 6BOOST steampipe manifold trust drag spec 115mm thick intercooler kit trust 4'' drag spec exhaust trust type r blow off valve splitfire coils trust pod filter in custom alloy airbox fuel system consists of a surge tank and twin bosch 044's in the boot with braided hose running to the engine with an alloy rail, sard fuel reg and 880cc seimens deka injectors. battery is an odyssey item located in the boot in a custom alloy holder along with the pumps and surge tank. drivetrain, suspension - custom exedy twin plate 1000hp clutch r33 gtr vspec gearbox TEIN coilovers trust strut tower braces front and rear wheels and brakes - WORK xd9 gunmetal 18x10 +17 NITTO nt05 275/35/18 tires in good condition slotted dba rotors and track spec pads body - garage saurus style fibreglass front lip standard gtr kit everywhere else with the rear wing removed bonnet lifted with washers to let turbo heat blow through paint in pretty good condition with only a few little scratches which have been touched up electrics and interior - Autronic SM3 ecu apexi electronic boost controller 4wd controller a large array of trust guages to keep an eye on engine vitals kenwood head unit 2 sets of pioneer splits and an alpine sub with 2 amps
asking $26000
contact Ben on 0413853519
or email [email protected]
car located in woodburn
northern nsw near Ballina
or hour and a half south of the gold coast
post-65459-0-54102800-1381406142_thumb.jpgpost-65459-0-10568600-1381406153_thumb.jpgpost-65459-0-81701300-1381406166_thumb.jpgpost-65459-0-51334800-1381406198_thumb.jpgpost-65459-0-99439200-1381406231_thumb.jpgpost-65459-0-54570000-1381406315_thumb.jpgpost-65459-0-03238500-1381406367_thumb.jpgpost-65459-0-88254000-1381406377_thumb.jpgpost-65459-0-02986100-1381406395_thumb.jpgpost-65459-0-97990700-1381406412_thumb.jpgpost-65459-0-68561100-1381406427_thumb.jpgpost-65459-0-63984600-1381406441_thumb.jpgpost-65459-0-69492400-1381406469_thumb.jpg
https://www.sau.com.au/forums/topic/433149-94-bnr32-gtr/
  • 3 months later...
. Would you be interested in swap for 2005 bf xr6 turbo. Has 320rwkw, 6 speed sports shift auto, clean, has almost 150000km comes with spool rods, cp pistons, arp studs, big actuator. Has a full exhaust, valve springs, injectors, fuel pump, oil feed line, zip kit in gearbox for firmer shifts, DVD player installed but haven't made the appointment for it to be wired up yet, gauges on dash, plazman 800 cooler, hot side cold side pipping, currently running on 13psi. If motor is built (parts supplied) it will handle 1000hp claimed by spool. Vic rego until November
https://www.sau.com.au/forums/topic/433149-94-bnr32-gtr/#findComment-7201449
it looks in the pics as though the bonnet doesn't sit flush with the guards near the wind-shield?
do you still have the boot spoiler?
do you have a dyno sheet? i'm interested how the trust single setup compare's to -5's or -7's at a similar power level.
Edited by ttoks
https://www.sau.com.au/forums/topic/433149-94-bnr32-gtr/#findComment-7201469
bonnet spacers mate for hot air to escape
https://www.sau.com.au/forums/topic/433149-94-bnr32-gtr/#findComment-7201486
hmm, look's retarded, and in the under bonnet pic there doesn't appear to be a spacer on the bonnet hinges, but at least easily changed if that's the case.
Edited by ttoks
https://www.sau.com.au/forums/topic/433149-94-bnr32-gtr/#findComment-7201581
Can actually see the spacers fine mate. You just need to look properly. To me looks like bit of washers used as spacers but can definitely see something there.
https://www.sau.com.au/forums/topic/433149-94-bnr32-gtr/#findComment-7202063
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
