Hey guys, just wondering if anyone could shed some light on an idling problem im having.
So the car in question is a 1994 R32 GTR V-SPEC II. From what I can see the car has a cat back HKS super dragger exhaust, APEXI pods, HKS EVC boost controller and turbo timer. When I got the car the AFMs were unplugged, an issue I would also would like to sort out (my guess is aftermarket ECU, but I was told it was stock when I bought it so I dont know).
So the issue is, soon after purchasing the car I straight away noticed a issue with idle first starting out as what seems to be just a slight misfire on idle ( the revs dont actually drop, the car just shakes alot but is stable around just below 1k rpm). Now when the car is like this and I turn it off and soon after turn it back on it hunts at around 500-200 rpm or just straight stalls. It usually just stalls but if I can keep it running itll soon stablize back to 1k rpm but still has the slight misfiring feel.
So I did some research and came to the conclusion that its most likely the AAC valve but I just want to confirm this before I start ripping things apart because it doesnt look like the easiest job.So any feed back would be greatly appreciated.
Thank you
https://www.sau.com.au/forums/topic/433744-r32-gtr-idling-problem/
Aac would normally be something to look at first, but the fact that the afms are disconnected on a stock ecu is really odd. I would be sussing that out first. How does the car drive? Also the usual plugs and coil pack clean/grease and normally clean afms/solder but on your case get them plugged in! What happens if you plug then in?
Well the car drives normal with them unplugged but one of the first things I did was find the plugs and plugged them back in. Made no difference so im guessing they were unplugged because it wasnt necessary for the car to run. So im also guessing cleaning out the AFMs wont help?
How does a stock GTR run without the AFMs not plugged in? Do they even run correctly without them? Is there anyway I can find out if its got a aftermarket ECU?
Edited by seventhirteen
Passenger side kick panel. Take it off and the metal box in there is the ECU.
If you cant work out what it is take a pic and post back in this thread.
Edit: If the AFM's aren't plugged in then it is likely to be Mafless (meaning an aftermarket ECU).
Edited by Sinista32
Uploaded with ImageShack.us
Yeh just took a quick picture. Looks pretty stock. How can it run normally without the AFMs plugged in? How exactly do they run without them in?
ok Stock
R32
RB26DETT
23710-05U62
Feb 93
Dec 94
2371M-05U62
MT
Maybe that's why it's running ruff (hunting etc..)
Go through what Superben mentioned above.
Checking further it could be a Mines re-written CPU too. Which wont change the above
Edited by Sinista32
Type the numbers into google - there is apost on GTROC which is a UK forum.
It appears to be a stock 93 ECU for R32 GTR's. Doesn't mean your GTR isn't a 94 Model.
Just means the ECU was made between Feb 93 and Dec 94 (I think anyways, but read the thread :thumbsup: )
EDIT: MT is Manual Transmission. 05U62 appears to be R32 GTR specific and 23710 is likely specific to ECU and date made somehow :wacko:
Someone else may know as I am just ASSuming :)
Edited by Sinista32
    • Welcome to !
    • As I've said elsewhere, I am using the stock intercooler piping path in the engine bay, and a return flow cooler, and making ~250 rwkW (without any effort put into trying to turn it up past there just yet) and expect to be able to make some more, and frankly, I would be perfectly happy with 260-270rwKW. This is peak road Skyline usability territory. You go past there and, sure, the car will snap necks more when it's on boost, but it will also break shit all the time, cost a (even larger) fortune in tyres, etc etc. Anyway, I also do not like the over-the-fan pipe path, and you don't have to do it.
    • I see, honestly I’m not too fussed about the looks. The only reason to go plenum is to make the piping easier instead of the classic over the rad etc.
    • Not easy to quantify wrt something like how many fractions of a second slower it would be over 0-100. But given that a 250-300rwkW car is able to do that launch sprint in 5-6 sec (and faster with appropriate tyres, and surface)..... giving up as much as a second would feel like torture. A ~450HP capable turbo is not going to make lots of boost in the 2000-3000 rpm range. So, whilst with some boost on hand it will be faster accelerating in that rev range than your engine currently is NA, it will not feel like a fast car until the boost is solidly in. You know what your car feels like right now when you open it up at 2000rpm. if you've ever been in an actual fast car, you will appreciate that the NARB25 is.... not exciting. Well, add some boost and it will be better. But shorten the intake runners and it might not be better at all. It might come out better, but it could end up feeling the same. For me, it's not the 0-X km/h sprints that matter. It is easy to fry the tyres with anything over 200 rwkW. You can't use all the power available in 1st and 2nd anyway, you have to modulate the throttle. What matters is how the car reacts when you're driving in traffic in 4th or 5th and have maybe 2000 rpm on board, and you want/need to add some speed quickly, and don't have time for the downshift. It won't make boost, it will be all NA (at the speeds we're talking about - remember how fast you're going at 2000 in 4th! and don't plan on breaking the limit by too much.) So giving away NA torque is not what I would consider practical for a street car. And retaining that NA torque builds boost faster which makes the car faster. The flashy plenum is not actually better, unless you're looking at a track car where you can keep it on the boil all the time.
    • So how much difference does it make you think? Like 1 second in the 0-100?  I was have smaller turbo so hopefully that spools quick GTX2871.  currently it’s NA so you can imagine pretty slow, but I do want fast accusation a little as there’s not many places I’ll be driving where I go over 80 even near me. So 0-60 and 0-80 targets
