Official Results
Bushfire Appeal Dyno Results
1. Peter VT 536kw
2. John XR6T 449kw
3. Damo VE 327.9kw
4. Marty XR6T 313kw
5. Blake F6 312.5kw
6. Marty SS 307.7kw
7. Ieuan Clubsport 302.2kw
8. Anthony Mirage 293kw
9. Blake Gemini 285.1kw
10. Chook Liberty 271.6kw
11. Shane 808 258kw
12. Luke VZ 239.4kw
13. Ronan TME 237.7kw
14. Wells XR6T 226.5kw
15. Travis VZ 221.9kw
16. James XY 217.8kw
17. Neil Jeep 206kw
18. Phil Supra 199.2kw
19. Tristan VY SS 194kw
20. Lincoln Evo IX 181kw
21. Dan WRX 180kw
22. Scott Golf R 177.4kw
23. Adam Pulsar 175.8kw
24. Eiji R32 172.4kw
25. Josh 180SX 165.3kw
26. Matt 180SX 158.2kw
27. Zac Liberty 148.8kw
28. Celeste Forester 146.1kw
29. Ravi MR2 145.6kw
30. Josie Pulsar 137.4kw
31. Kurt RX7 130.1kw
32. Mark Pintara 122kw
33. Tony Lancer 119kw
Yeah i had to chase up a couple of things in the morning. I popped out and said hi but didn't get a chance to enter anything. 536KW huh? Not bad.... I should have entered the dyno if i had the chance : |
  • Like 1
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
