i have a front bumper bar and lower lip to suit r33 gtr , just the bar no blinkers no grill , the b/bar is in very good nick mica red the lower lip has some minor scrapes under it and its black as it comes on the orginaly not painted , both are genuine i'm after $ 550 for the lot .
before you ask me if that will fit a gtst , i cant tell you yes or no make your own inquiries , im in sydney
https://www.sau.com.au/forums/topic/43464-front-r33-gtr-bbar-fs/
no lip mate , they are very hard to find second hand ( they scrape and easy to damage )
no idea how much to send to bris . whats wrong with yours blitz ?
The car came with a 400R front 2 piece bar. Originally the lower lip and side of the top bar was damaged, had to get it all fixed again. Now its all been fixed, i still has trouble with the lower lip because its to low to the ground..
I would much rather a gtr front bar as they are plastic (flexes instead of cracking) and itsnt as low to the ground as my 400R bar.
Yeah, gtr bars without the lower lips look a little silly. I did ask around on SAU for a lower gtr lip a while ago, but ppl wanted liek $400+ for the lip alone.
Good luck with you sale!
gor33, it is a STOCK gtr bar , its not aftermarket its stock plastic bar .i have a n1 b/bar in my gtr , again stock nissan plastic item so i don't need this one .
what car do you want to put on ?if its r33 gtst find out if it will fit first . why do you want a pic ? if you are interested in buying it and you want to see the condition of it then i will take some pics but if you are not i don't want to waist my time . let me know amd pm or post your email .
  • 5 weeks later...
i have a moroon R33 GTS-T - very interested in a GTR front bar. I do require to see some pictures though. Either upload or E-mail..
[email protected]
I'm based in Sydney..
Thanks
myr332 ,
why dont you come over and see it , u cant see much from a pic .
its just the bar though no lip of lights on it and i dont know if it will fit on a gtst , find out first .
I'm also im after a GTR front bar coz its plastic, i cracked my 400R coz its too low, using the stock-o bar now.. Im thinkin a GTR would be good. Do you know if they're any lower than a 400R *including the lip*. Could you give any pictures or measurements of the height. Also what series year model 33 was it taken from?
Cheers
now with lower lip as well $550 for the lot
jamesh3 do you have a gtr ?
this b/bar came off a s 1 gtr but s2 is the same not sure if they are higher than 400r but my car is standard hight and the lip is 175 mm of the ground at the lowest part ( in the middle )
keep in mind that it will hit sometimes when you go in a dished drive but it wont crack you just scrape it underneath .
i have someone thats interested in the b/bar but have not sold it yet
That sounds alright, I like that fact that its plastic and will bend rather than crack first * i dont care about it scraping underneath. Ummm I'm going to go measure my car's ride hight right now *its been lowerd*... I have a r33 GTS-t 95 series 1.5. Series 1 body with the series 2 gear. I'm going to have to find out if it'll fit. Sounding alright so far. If it comes down to it, & i had to try and see if it fits on would that be ok, if it fits obviously i'd buy.
Cheers,
James
Cheers,
James
you are welcome to come to my place and try it out , let me know when you want to do it .
as for the hight i think the gtr maybe lower than a standard hight gtst .
i'm not sure on that one though .
Measured my car just then... dam its cold outside... :drooling:
The lowest part hanging off my car is an inch long metal plate off bottom of intercooler to warn me when dangerously low & scraping.. and that’s @ 140mm. The lowest part on my stock front bar is 160mm.
I'm thinking i may as well come and try it out.. just before i do, could i please get a photo or something, I want it to be in good condition, don’t care about scrapes under lip tho... and yeh. I'll PM you.
Cheers
where abouts are you in sydney ? i dont have a pic i guess i could take one for you but you are not going to see much in a pic . is your car the same colour ?
the bar is in good nick no dints no cracks even the paint is good , the lip has the usual scrapres underneath but no cracks or dints .
anyhow let me know if you still want a pic and ill get a couple for you tomorrow .
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
