Skimmin across the internet today and stumbled across this "Voltage Stabiliser". Earthing kit with condensers
Looking for real experience and thoughts from the technically capable.
Claims
·Improved audio quality
·Increased torque and response and power
·Stabilized idling and improved engine kick over
·Increased headlight brightness
·Improved fuel economy
·Improved battery
Seems there was a group buy way back when and 31 were sold. So any good ?
http://www.pivotracing.com/product/VS-M
or is it just a croc
IMO, it would improve the flow of electrons if the car body (rusty) is old, by having more grounding points from the battery to the car body since almost every circuit uses the car body as an earthing point. also it functions as a capacitor as what is used in ICE...but other than that...these things are usually overpriced for their purpose.
Clean, rust free factory grounding points will do just fine. The grounding kits were all the rage ages ago, then people released they are about as useful as the "energy polariser" on hdt vl commys, fuel line magnets and vortex generators for your intake
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
