I have brand new Yellow Jackets coil packs for $420.00 delivered via express post.
Great value for money and come with a 2 year warranty.
For more info or to purchase - http://performance-wise.com/userimages/procart28.htm
I post daily so if you order before 12:30pm you will have them the next day.
:cheers:
Hijacking the thread lol - I'm looking for a set of new aftermarket coil packs aswell... Only issue is I can only pay cash!
For what engine? I have some for an R32 GTR RB26. Splitfires only used for approx 500kms $450 located wollongong.
