Hi All
I am looking for interest for my 1992 R32 4 door Skyline, charcoal in colour 70 000 ORIGINAL kms..... This was a private import from a friend in Japan and it has original Japanese log books.
There has been a lot of money spent on this car…
What you get:
Outside:
GTR front end including bonnet
R32 GTR wheels with lots of rubber and GTR brakes
Lowered 1.5 inches
Dark tinting
Inside:
GTR dash and display i.e gauges are GTR set up with NISMO 260km/h speedo
Pioneer head deck, with Alpine speakers
Engine:
Full 3inch exhaust
Upgrade R33 turbo
GTR fuel pump
FMIC (Plazma Man)
Boost controller
GTR inlet manifold (This was a bitch of a job!!, but well worth it)
1 year NSW rego
Immaculate inside and out, looked after very well… and even though I am biased I still haven't seen a 4 door in as good condition.... If you want higher res pics drop your e-mail address in a reply....
Looking for around $19 000
https://www.sau.com.au/forums/topic/43546-modified-r32-4-door/
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
