Hi guys,
Only just signed up to this forum so really excited to hear your thoughts and ideas when it comes to GTR financing.
At this stage i am looking to get one in the next 6-12 months - It's been on the shopping list for a while now and after just recently going off on my own and establishing my own business i am now in a position where i can afford to do it!
I'm most likely looking to buy one second hand (probabaly 2011-2012) and would prefer a balloon loan arrangement.
Does anyone have any advice for me regarding best interest rates out there atm, nissan financing (are they decent?), importing the car (is this even possible and a cheaper alternative?), any other advice you can give me
Thanks guys and look forward to hearing from you all
Jarret
https://www.sau.com.au/forums/topic/435530-gtr-finance-options/
You have quite a few options to finance your GTR. As it will be a used vehicle expect rates to be a little higher using major banks. I will eat my hat if NAB will do 5% on a used vehicle. A private broker or even dealer based finance will be your best bet. Be prepared and negotiate not just rate but any origination or brokerage fees.
And remember 5yr 30% balloon equals roughly $40k on a used GTR at $120k so be ready for when that comes around.
Hey Sam, who do you aggregate through?
To Jarret, if Sam isn't practical due to geographic location, let me know where you are and I'll put you in touch with a finance broker.
Also you won't get 5%. Expect closer to 10%.
mmmk so secured commercial loans will attract a lower rate not higher.
the trade of for this is you are not protected by the UCCC cosumer regulations, this realistically boils down to costing more if you cancel early and loosing some protection aginst charges, this is a very basic explanation.
i finance a few of these and im happy to help if you need. just pm me bud.
If you are considering buying the vehicle through a dealership i would strongly suggest sitting down with a business manager and tell them you're comparing rates.
Firstly sit down with your bank and see what you can do, go back to the dealer and get them to better it.
This is what a lot of my customers do and end up saving themselves some money.
I am a business manager at Lynford Motors in WA. I Financed a 2010 GTR we sold a bloke in QLD and wasnt difficult.
Rates do depend on a lot but we have bigger buying power than most so our rates are usually a bit lower. A bit on 120K can be a lot though!!!
Give me a call if you want to discuss Jarret 08 9242 9061
Ahhhh....I thought you were a finance broker.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
