Hi guys, up for urgent sale are the below items. Prices are negotiable as it all needs to go this week! Parts came off my R33 which made 304rwkws at Chasers on 21psi. All items have done less than 5,000km
Contact: Dean / 0401 682 270
- Garret 35/40 Turbo with .82 rear. Very good condition, done under 5K since new
$750ono
- Stainless steel RB25 highmount manifold
$750ono
- 38mm external gate (brand to be confirmed, worked very well)
$250ono
- Stock R33 Cat Back exhaust $165ono
Yes it is genuine and yes it does have stamps. If you're genuinely interested, please msg my phone rather than post comments on here as I'm rarely on the forums. Prices are negotiable as everything must go!
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
