hey guys,
Sold a few thing on here without much hassle :) so lets try again
this is my SELLING MY SPARE CRAP TO FUND A HOIST SALE.
PICS AVAILABLE ON REQUEST, too big to attach..
All located Newcastle NSW, can ship smaller items at buyers expense.
Parts all functioning and in good working order etc. all parts have been taken off due to upgrading all priced to sell. this shits cheap.
1) Rb26 2.5" split dump into 3" front pipes. Turbo to cat. flows well. i was making 361kw with this exhaust setup. $250
2) Sard 550cc RB26 Injectors, in prefect working order, ran perfectly on 361kw at wheels. took out as i am running E85 now $250
3) RB26 Stock Blow off valves $80
4) SR20DET Dump Pipe with screamer pipe.. sounds insanely good on gate. $50
5) SR20DET Steampipe manifold, will never crack like the stainless china copies $180
6) Rb26 Twin Turbo Top Pipe, $30
7) 2 x rb26 Intercooler pipes, 1 x top hotpipe and 1 x lower hotpipe $30
8) 19 x 8 wheels +35ish offset from memory, 4x114.3 , with BRAND new china special tyres, these were my defect clearing tyres, still got the little rubbers on the tyre. like seriously 99% tread, $550. looked good on my S13 before i went wide body.
https://www.sau.com.au/forums/topic/436299-more-r32-gtr-stuff-and-sr20-stuff/
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
