1089 is the integer after 1088 and before 1090. It is a square number (33 squared), a nonagonal number, a 32-gonal number, a 364-gonal number, and a centered octagonal number. 1089 is the first reverse-divisible number. The next is 2178 (= 1089 × 2 = 8712/4), and they are the only four-digit numbers that divide their reverse.
Its the magic number :merli:
Cool, I'm excited! but where's the pic Mik? :closedeyes:
Edited by THE34T
