Firstly, sorry to iwanta34gtr for hijacking his thread, this discussion needs it's own thread.
Again, bottom end balancing should be carried out as a complete rotating assembly, correct?
If you dramatically change 1 part (eg reduce your flywheel weight by half - lets say 6kg), will it not throw out the balance of the bottom end? Yes it will.
Dual mass flywheels are designed to deliver a smoother power delivery with less vibration, correct?
So ineffect, do dual mass flywheels in a way, function the same as a vibration dampener? I would say yes.
So, by removing the dual mass flywheel & fitting a single mass flywheel are you ineffect allowing a higher torsional frequency to occur at certain points in the rev range? I think so, hence my original statement.
Adam, why would you only balance a rotating assembly if it was externally balanced? Any rotating assembly should be balanced regardless of how it is balanced!
Yeah, sorry iwanta.
No - if the new and old flywheels are both in good balance it will make no difference to the balance. It will change the frequencies that the crank/flywheel assembly resonates at, but thats the twist along its length, not the rotation. Think of it this way - lets assume the crank is infinitely stiff, so it cant twist along its axis. Now lets say one of the big ends is heaver than the rest, then as it rotates around its axis it will produce vibration. Try putting something eccentrically weighted in a drill and see what happens.
Now if we assume the crank is perfectly balanced, but is not perfectly stiff (ie its like a big spring), then it wont vibrate in a radial direction. If we now sit on one end of the crank and look at the other end of the crank, we will see the other end twist forward and back a little, due to the action of the rods applying force to it. This twist will put no force at all on the mains bearings, unlike an eccentric weight.
I know i didn't describe that well. I think about it some more and see if can work out how to describe it better.
I might not have described it well. For an internally balanced motor, you balance the crank/rods/pistons together. The balancer and clutch assemblies are balanced separately (they should be supplied balanced) so you can swap one well balanced clutch assembly with another well balanced clutch assembly without having to pull the motor apart to rebalance everything, as stated above by GTRPSI.
With an externally balanced motor, there will be eccentric weights on the flywheel and/or balancer, which form part of the crank counterbalancing so in that case you have to balance the balancer/crank/rods/pistons/flywheel together.
But again im not an engine builder, so i'm only moderately confident i understand this stuff.
I know & understand the processes & finer points of balancing an engine, as I build engines.
Replacing a flywheel is all well & good as long as it is zero-balanced.
Most manufacturers will either dowel a flywheel to a crank, or, eccentric bolt a flywheel to a crank for the purpose of balancing. In some cases this is done for timing purposes (Rodeo V6, as the crank trigger is on the flywheel)
My flywheel is dowelled.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
