Parting out my Gtr , hks 2530 turbos like new quick sale $800 no shaft play at all, these will go like hot cakes payed $2500 them new ! Tomei type B cams like new $200,Only reason so cheap rego is due on my wife's car, and the little turbo rice car has to go, will post registered express to buyer any where in australia.
https://www.sau.com.au/forums/topic/437382-hks-2530-turbos-like-new/
Do both these turbos come from a RB26 as both housings look different to normal 2530's from a RB26 no divider between the wastegate and exhaust wheel and one has the actuator mounted in a different position to the other they look to be from a 300zx VG30DETT engine ,do they both have the same matching numbers on the ID tags and is the tag in the photo from that turbo as that photo is from a ad on SAU from 2005 selling a SR20 turbo
http://www.skylinesaustralia.com/forums/topic/67061-fs-hks-gt2530/
Edited by gtr13
I've been trying to buy the cams off of this person, was quick to send me bank details minus his name but won't contact me via phone and won't send photos of the cams with today's date. Be aware people!!!!
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
