1. Semi Slicks
2xBridgestone RE55S 235/40/17 and 2xToyo R888 225/45/17
The RE55S is on the wear marker, the R888 is about 1 or 2mm above wear marker. Suit someone who wants to take it to skidpan day or perhaps the drags. What the heck $50 for the 4 tyres and I can hook you up with tyre fitting 1/4 price than normal shops.
Price: $50
2. Rota Grids white, 17x9.5's (x2) and 17x9's (x2) both +12 offset
Been sitting doing nothing for a while hence collecting dust. Two tyres are brand new, stickers still on it, two tyres are bald. Minor blemish on some but nothing that cannot be fixed with a polisher except for the one in the photo that has a minor gutter rash.
Price: $750
3. R33 Body stiffening brace
Mounts on the bottom of your b pillar, uses the seat belt bottom mounts so it is a direct bolt-in install. Stiffens up your boat.
Price: $100
4. R33 roof lining
Good condition to replace your soggy cumstained ones
Price: $20
5. R32 Passenger side quarter window
Removed from car and ready to go, good condition.
Price: $100
6. Battery Jump Starter SCA 1900A
Good working condition, just lost the charging adapter when moving house. Charging adapter can be bought cheaply from battery world etc, charging polarity and amperage is labelled. Unit was ~$180 new from supercrap.
Price: $70 o.n.o
7. R33 leb spec GTR style wing
Red/maroon in color, looks like the one in the photo.
Price: $100 o.n.o
Contact: Kev 0433 220 four four nine
Edited by kliono
R33 B Pillar Brace Sold
Jump starter Sold
The one wheel with the minor gutter rash has been fixed and the rest all polished up ready to go. $750 FIRM, if you can't read this don't bother, too many time wasters.
  • 2 months later...
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
